ArchiCAD 9 Add-on for Artlantis R is available
The new export add-on from ArchiCAD 9 to Artlantis R is available in beta version Mac or Win in our web site:
http://www.artlantis.com/download/update/
It is compatible with ArchiCAD 9 only. As a beta version it means it is not yet finalized. You agree to use it at your own risk, although internal tests have been successful.
This add-on has been developed by Abvent, the previous ones were made by Graphisoft.
Enhancement since 4.5 add-on:
- UV map applied in ArchiCAD are now taken into account, e.g. on a multi slopes roofs, the veneer of textures keeps its original position.
- ArchiCAD objects keep now their applied textures.
- ArchiCAD default Heliodon is retrieved.
- All materials are now smoothed to zero (Use the material smoothness cursor into Artlantis on curved geometry), the goal is to avoid smoothness problem between Walls and slab with same ID material.
Help us to improve this product, so please feel free to give us your feedback.
Best Regards,
Pierre
Abvent s.a
11 Replies 11
Djordje
Thanks for the info, Pierre!
Where do we send the comments/bugs?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje,
All the comments and bugs can beings send on
http: // www.artlantis.com/support/forum/liste.p hp? Fid=atl_import_us
or send at [email protected]
Pierre
After one quick test of a large model, I am thrilled that the new plug-in exports UV mapped surfaces correctly. No more bizarre roof textures for the imported model like we put up with in 4.5 and earlier.
I saw some things to test further, but this is off to a great start by eliminating the chief complaint about the old plug-in.
Thanks, Pierre,
Djordje
Pierre wrote:
All the comments and bugs can be sent at
or sent to [email protected]
OK, thanks
Now another question: why is a new login requested for the Art•Lantis web site if you are already logged in at Abvent Web site?
Djordje
HP Omen
Djordje,
No, the login is the same for artlantis and abvent sites
stefan
I'm really glad to hear that the UV-mapping problems finally got solved! This was one of my major gripes for Artlantis, back from version 3, IIRC.
No see if I can test it? Nope. My demo has expired... Sorry
Archicad-user since 1998
my Archicad Book
LiHigh
Do you guys have problem converting Lights. My experience was that lamps were lost in the export process. But, with the same setting in Archicad, export using the 4.5 addon is ok!
What's wrong?
Howard Phua
Win 10, Archicad 19 INT
Djordje
Pierre wrote:
Djordje,
I know; but, if you are on Abvent, and click on the link to Art•Lantis, you have to log in again?
Djordje
HP Omen
LiHight,
"Do you guys have problem converting Lights. "
Are you Windows or Macintosh user?
If Macintosh user, yes, it is right . We correct this. (It is a beta version)
If you are Windows user, check and select in Image menu/RenderPhotorealistic Options/internal Engine/Effects/Lamps On (See attachment).
Thank you, and all comments are welcome...
Pierre
