Visualization
ArchiCAD & LightWave - workflow?
Eduardo Rolon
You are aware that there is a Maxwell plugin for AC.
http://www.nextlimit.com/maxwell/integrations/
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
1 REPLY 1
Eduardo Rolon
Original post before banning user
I need to get some buildings from ArchiCAD into Lightwave, where I will do the scene set-up and texturing before I send it to Maxwell for final rendering.
Any tips, tricks or hints on the best workflows are very welcome!
Btw: Lightwave-Maxwell integration is super smooth, the only issue is what the best way to input the ArchiCAD files to Lightwave would be...
AC29 US/INT -> AC08
another Moderator
