More indepth analysis
![](/legacyfs/online/emojis/icon_wink.gif)
Two important new features related to maxwell 2.5 are :
- the fire engine (Fast Interactive REndering) the main evoltion is this one as it brings a realtime rendering engine as demoed in
http://maxwellrender.com/
- the draft render option.
the ArchiCAD plugin has not been updated ( yet ?!) to integrate those two new features .
And while waiting for the plugin's update, here are the possible workflows:
- for the fire engine .......the only workflow now is to export to Maxwell studio and lunch the fire interactive engine from there
- maxwell gives now the possibility to have what they called "draft rendering" which faster than the "production one".it intended to be used as a preview one and gives already very good results ( actually it is the one fire engine uses ) .......for this one there is a way to lunch it directly through Archicad plugin by entering "-rs:0" in the command line, you can get back to the default one by entering " -d -p:low "( this workflow is the same for the sketchup plugin...it is how i know it could be done in Archicad Anyway
😉 ) . another option is to enable this mode in the render window options ...
AC12_27 |Win11_64bit|
