Visualization
ArchiLumos 2.0
Steve Jepson
A new ArciLumos will be released when ArchiCAD 9.0 comes out.
http://www.optgraph.com/archilumos/hottopics.html
21 REPLIES 21
Steve Jepson
Be sure to check out the gallery.
rm
Renderings look great. One MINOR problem,......no Mac version noted on their site.
Robert Mariani
MARIANI design studio, PLLC
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
Steve Jepson
..so get rid of your Mac and get a REAL computer.
Dwight
Shouldn't be a problem for Mac - they supported it in the past.
Dwight Atkinson
Dwight
BTW: How many are using Archilumos besides me?
Dwight Atkinson
Eduardo Rolon
3D Viz, Artlantis, C4d. Not enough neurons to handle another program
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Dwight
Archilumos advantage: Built-in plug-in - no file export.
Dwight Atkinson
Vitruvius
I checked the site and they do support Mac - it's just the demo version which is listed as Windows (though as a plug-in presumably it'll swing both ways?).
Can anyone tell me how this programme differs from AV-works?
Cameron Hestler, Architect
Archicad 27 / Mac Studio M1 Max - 32 GB / LG24" Monitors / 14.5 Sonoma
Dwight
This program produces a radiosity solution of high quality.
Radiosity differs from ray-tracing [as AV_WORKS creates] because it considers the color of reflecting surfaces in light rays.
It does a superior job to AV_Works as you can easily see from the rendering examples, although those images are done at very high radiosity mesh resolution - that takes a long time to solve - but a radiosity solution is made once for a model so subsequent images are really quick.
Lumos doesn't tolerate modeling conflicts well and cannot employ picture-mapped objects. 3D trees really slow it down, so one is limited to simple interior renderings....
Lumos also can employ the IES profile of light fixtures in solving a scene - allegedly meaning more accurate light effects.
While it is a straight forward plug-in, its radiosity quality is impaired because it uses the crude material definitions provided by ArchiCAD, lacking, for example, sub-surface reflections that enable subtle effects like marble.
Dwight Atkinson
