gpowless
Archicad 18 CineRender
Problem encountered:
CineRender will render model for a few times then it stops. Photorendering starts in a "Preparing...0%" then "Done" without any rendering.
Anyone of the testers or Graphisoft have any ideas?
Intel [email protected] 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
16 Replies 16
Barry wrote:
If you think it might be the video card then make sure you have the latest drivers installed.
Hi Barry
Maybe read my posts better, you will see that I have gone the conventional route and I have been in the game for a long time, so I wont post a problem unless I have exhausted all options to try and fix the problem... don't just state the obvious, please help me.
A related problem, is my copy and paste function. When I paste from a capture I can see the paste till I click to place and it simply disappears in ACAD 18 in ACAD 17 it creates a black block... It does not seem that there is a lot of people with this problem.
So I will have to replace the Graphics card and see if that fixes it...
Zak wrote:
Hi Barry
Terribly sorry but not once did you mention that you had updated you video card drivers, nor your level of proficiency nor what you had done to try to fix the problem apart from that it worked on another computer with no problem.
Zak wrote:
This is hugely frustrating, I have black preview and render, even when I save the render it still is just black. Is it a graphic card problem or what? Nvidea 570 Twin Frozr. I can't paste pictures into Archicad either, once I click outside to place the picture it just disappear... separate issue I know but I think it is graphic related? Help!?
Zak wrote:
The same scene just opened on another computer without any changes, renders fine. It does not matter how I do the settings or use a preset, it stays black. So the only thing that I can think is a graphics problem, but why and how do I find the actual problem that is causing it?
I have no idea what you problem is as I am not sitting in front of your machine.
I'm just trying to eliminate the obvious as more often than not that is the solution.
Does the other machine you tried have exactly the same specs (especially the video card) as your machine?
If you do a screen capture and paste that in an e-mail or another program does it look OK - is it just Archicad 17 that it goes black and 18 that it disappears?
Again I may be asking what seems to be obvious but I have no idea of what you have tried.
gpowless
Update: The black render seems to be model specific. I just opened another instance of AC18 and it rendered simple walls fine. In another instance I have a model that does not render (only black without and progress).
I originally started this in AC17 (Cadimage delays) and then opened it to AC18.
GS. Any clues? Is this a known bug issue?
gpowless
Ok, this is too weird.
I have isolated the model issue to the roof layer and the roof composites contained on that layer. I have other roofs in the model as ceiling composites that seem to have no problem.
When I turn off the roof layer, it renders correctly even with the ceiling layer and the ceiling compostes on. I have tried to isolate the roof but to no avail. It still doesn't render. (black preview & render window)
What could it be?
gpowless
5 hangs on 2 machines on render. No keyboard, mouse control, or task manager. Had to turn the machines off and on and do a complete reboot.
Why does Cinerender have system level control? There should at least be a way to shut it down when it hangs!!!!
I have the same problem in ArchiCAD 18 CineRender.
I am thinking that the problem is between NVIDIA and the CineRender.
this thread is already a bit old, anyway, here is what i guess:
I had or have this issue, too: only white / black images or half-done renderings and cinerender quotes DONE. I discovered that cinerender needs enormous amounts of free hard-drive space as cache (even 200gb free space is sometimes not enough in my case), espacially when using displacement mapping, like some roof-textures do. I assume that that if theres not enough free disk-space cinerenders stops working and quotes: DONE.
(@Graphisoft: how about an error-message?!)
In Cinema4D you can set the amount of ram cinema will use for displacement-mapping. It seems, that cinerender uses nearly no ram for this on my machine (i have 16gb ram) and therefore needs vast amounts of disk-space to cache the displacement-calculations. Is there an option to set this also for cinerender in archicad?
Don't know if i'm guessing right, but do i really need to have 300gb free disk-space for an rendering of 2339x1305 in low standard settings but with displacement mapping for a few roofs-textures?
