Nada
Archicad 25 Elevation missing texture fill
Hello everyone,
I am very new to the Archicad program. and I am really happy to join in to learn more.
I liked the idea of the appearance of the elevations with the material I select for walls and other objects. but unfortunately it worked once and then it disappeared. I tried redoing the same elevation default settings again but it shows just colors with no presenting for the real material.
can anyone please help.
Screen Shot 2022-04-23 at 11.49.40 PM.pngScreen Shot 2022-04-23 at 11.49.57 PM.pngScreen Shot 2022-04-23 at 11.50.12 PM.png
3 Replies 3
scottjm
Mentor
Try turning off Fade Distance Elements, or adjust the settings of Fade Distance Elements so Uncut fill is also set to "Surface - Texture Fill".
Lee Hankins
Also, make sure you don’t have any Graphic Overrides active.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Nada
Thank you for your support. I just figured out the problem!
I was changing the settings for elevations but it did not make any changes to any of the elevations. so we I entered the settings of the East elevation that is when the view changed. so apparently I need to change every elevatons' setting separately and this is what solved the problem.
Thank you for answering, and since I am new this is not going to be my last question 🙂
see you soon.
