ā2022-05-17 09:52 AM - edited ā2022-05-17 09:53 AM
ā2022-05-17 02:20 PM
If you check the detailed settings for the cinerender engine, the ussual things that shift tone and brightness and such are found under 'effects'.
You can also check 'global brightness' all the way at the bottom under 'options > general options'
