Archicad Rendering engine
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2004-10-31
09:00 AM
2023-05-11
12:40 PM
Noemi Balogh
2004-10-31
09:00 AM
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-10-31 01:23 PM
2004-10-31
01:23 PM
Unless there is some limitation to the student version you should be able to set the rendering size quite large (I forget the limits as I have never needed to exceed them).
The setting is in Image > Rendering Settings > Image Size and Background. Remember to keep the proportions of the rendering the same as the 3D window or you will have blank stripes on the sides or top & bottom.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-10-31 05:50 PM
2004-10-31
05:50 PM
The max horizontal pixel count of a rendering is 4096 or so pixels; should you need more, turn your camera sideways.
What you see in the rendering window does not matter; the image will be saved at the pixel count as Matthew explained.
As the standard ArchiCAD engine is not so great, maybe you can try to do the Sketch renderings - much more "architectural"
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-11-01 09:48 AM
2004-11-01
09:48 AM
it is set to use the proportions of the 3d window but its does just as you say it shouldnt; have blank strips at the right and bottom once saved the strips go the rest of the image still isnt there. is there something wrong with the settings in my 3d window or is it a limit to the student version? im sure i managed to make a large rendering on my pc but thats got student version 8 (not 8.1). Have not played around with the sketch rendering engine, but i might just do that. thanks for the help
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-11-01 10:00 AM
2004-11-01
10:00 AM
oh and just another thing, how can i stop a rendering? for example i forgot to turn some lights on and dont want to wait half an hour for it to finish knowing im just going to delete it. on the pc i had to resort to ctrl+alt+del but then i had to close archicad completley
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-11-01 08:20 PM
2004-11-01
08:20 PM
neil wrote:Don't you have a progress dialog box with a big STOP button?
As for the proportion - yes, it should be to 3D window. Make sure that you set the pixel size in one box only, the other should resize according to the 3D window proportions.
Djordje
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-11-01 09:29 PM
2004-11-01
09:29 PM
After doing some testing i think i've isolated my problem to being that the student version of AC 8.1 seems to limit rendering size to a ridicuously small size while the student version of AC 8 does not. I thought the student versions only limits were that the commercial version cant open student version files, and student version prints with watermark around the edges. is it just a setting i can change? i looked around and found "partial photorendering" but changing that didnt solve it. I think im going to have to install the student version of AC8 to get my renderings finished. im pretty sure i cant open a file made in AC 8.1 in AC8 but can anyone tell me if i can save as an AC8 file or if an archive file saved in 8.1 will open in 8. Thanks for the help
neil
neil
