Visualization
Archicad Rendering
I'm trying to render an external image of a vertical batten facade, but are having great difficulty getting the screen to look sharper. I was wondering whether anyone had a similar experience and knew how to fix the issue.
I have attached screenshot of my render settings.
I'm using archicad 19 on a PC.
Any help would be most appreciated.
Tommy
undefined
7 REPLIES 7
settings attached.
I have also tried rendering it on 'final detail' settings, but haven't had any luck.
screenshot
undefined
Walter,
All you can do is to increase the resolution
Scott
Thanks Scott.
So is it worth adjusting the antialiasing settings or should I just stick with the standard?
Walter,
I would just render a larger image as adjusting the antialiasing settings can would require a bit of experimentation and could take longer than just rendering a larger image.
Scott
MuazOnline
Hey Walter,
always try to use Anti_aliasing with Sinc filter (it's there in the drop down menu) so you can get most real and sharp rendering.
Jacques Toerien
I'd stick with standard and simply render larger. You can downsize in Photoshop / Krita / Gimp as required.
2012 13" Macbook Pro 8GB Ram, OS X 10.14.6
2010 Mac Pro 2x 6 Core 2.93Ghz Xeon, 48Gb Ram, OS X 10.14.6, RX 580
To summarize the summary of the summary: people are a problem. - Douglas Adams
