‎2004-01-16
12:25 PM
‎2023-05-11
01:13 PM
Noemi Balogh
‎2004-01-16 12:35 PM
‎2004-01-16 01:38 PM
‎2004-01-16 02:00 PM
‎2004-01-20 03:31 PM
Fabrizio wrote:Thank you, I did it!
I just describe before the procedure to follow!
If you have a FULL version of ArchiCAD (with all the standard add-ons properly installed) do the following:
1. Display a 3D view of your model (only perspective!)
2. With the 3D window in front of all, use the File/Save as... command
3. In the displayed dialog window you can choose .ATL format
BTW, the save formats change referring to the current active ArchiCAD window (for this reason, in order to export in .ATL format you must have the 3D window in front view)
Friendly
Fabrizio
