ā2004-05-18
12:58 PM
ā2023-05-11
01:13 PM
Noemi Balogh
ā2004-05-18 01:06 PM
ā2004-05-18 02:03 PM
ā2004-05-18 03:38 PM
jazzdude wrote:Yes & yes.
I do not much about cinema 4D but have seen images done in 3D studio max and they are stunning. But like everything I bet you have to mess about with loads of settings to get that. Is cinema 4D realistic and does it have radiosity?
ā2004-05-18 05:41 PM
jazzdude wrote:IMHO using it for rendering only is like taking a plane to the corner shop - yes, the results are stunning, IF you know how to get them. That takes time and a steep learning curve, nothing like Artā¢Lantis. This is true for any high end rendering/animation package.
I had a look at it on a friends computer and was bewildered by the features.
What i would like to know form you guys is how difficult is it to learn and use for rendering only (I will still build the models in Archicad) and to get results better than those of Artlantis?
ā2004-05-18 07:04 PM
Djordje wrote:Certainly it is more complex to use than Artlantis, but it is also much more capable, and Jazzdude was asking about going beyond Artlantis to 3D Studio (not a trivial jump either).jazzdude wrote:IMHO using it for rendering only is like taking a plane to the corner shop - yes, the results are stunning, IF you know how to get them. That takes time and a steep learning curve, nothing like Artā¢Lantis. This is true for any high end rendering/animation package.
ā2004-05-18 07:06 PM
ā2004-05-18 07:23 PM
ā2004-05-18 09:18 PM
ā2004-05-18 09:41 PM
Matthew wrote:Nope. ArchiForma.
As it turned out the curved signage was not approved and so minimal time was spent on the alternate. (If it had been approved I would then have figured some way to get the sign model into ArchiCAD - probably 3DS)
