2006-04-21
10:33 PM
2023-05-11
01:10 PM
Noemi Balogh
2006-04-22 05:28 PM
RobertNichols wrote:The PlugIn is at the Art•Lantis site in the download area. The installation is semi-manual. Be sure that you replaced the export dll of the original Graphisoft PlugIn.
I've put what I believe is the correct plugin (ArtlantisR_Out) into the ArchiCAD 9:Add-Ons:Import/Export folder on two machines. One machine allows me to save in ArtlantisR format, the other doesn't. To troubleshoot the bad machine, I made sure ArchiCAD 9 was current. Now it is; no change with respect to the problem.
RobertNichols wrote:No, it has not. Now you do it in Art•Lantis - Open with reference. Check the Tutorial movies on the Art•Lantis web site.
Also, when I do save out to ArtlantisR format, do I no longer get options having to do with reference files? Did workflow moving model changes from ArchiCAD to an existing Artlantis project take a step backwards?
2006-05-04 03:42 AM
2006-05-04 05:53 AM
Steve wrote:Did you re-install the plugin? Maybe the update wrote the Graphisoft plugin over the Abvent plug in?
I can't seem to use my Art*Lantis R anymore either. Not since I upgraded to 2219.
2006-05-04 06:53 AM
2006-05-04 02:20 PM
RobertNichols wrote:R is the same pain, just different. And NO documents!!!! Abvent has been the same since 1985. Good software, bad support. But the forums are helpful. Especially Krippahl! And the results are worth the money!
I've signed up with Artlantis to see how "R" treats me. I've always liked the speed and results of Artlantis 4.0, but thought the interface should be in a Museum of Pain. I'm hoping "R" has addressed some of that (it looks like I can describe position in feet and inches...good start!)
2006-05-04 03:49 PM
2006-05-04 04:25 PM
2006-05-05 01:11 PM
2006-05-05 04:41 PM
