‎2006-09-04
12:04 PM
‎2023-05-11
12:59 PM
Noemi Balogh
‎2006-09-04 01:49 PM
Light Sources
150% Ambient (color - light mauve), and Lamps
LW SunGood, maybe increase diversion angle to 5deg for smooth sun shadows
Color Yellowish, Intensity 80, Light Source 10, Dever. Angle 2 deg.
LW SkyObj.Good, shadow quality at least "4"
Color Light Blue, Intensity 60, Lat. 3, Long. 10,
UndersunGood, tip - set angle at -88deg or less (not -90deg), and azimuth parallel to the camera view axis, this way you will light up side of those beams under the ceiling so it won't look strange
Color Yellowish, Intensity 30, Light Source 15
General LightHonestly, I never found this light useful (sorry Dwight
Positioned behind of the camera, Intensity 40, Color Yellowish, Distance Fall. 1.00, Height 3'
Window Lights up to ceilingGenerally good, but:
Color Yellowish, Intensity 70, Light Res. 2, Shadow Quality 3 ,Height 3'
Window Lights from ceiling to floor
Color Yellowish, Intensity 70, Light Res. 2, Shadow Quality 2, Height 3'5''
‎2006-09-04 04:22 PM
‎2006-09-04 04:29 PM
‎2006-09-04 05:16 PM
‎2006-09-04 06:14 PM
‎2006-09-04 07:26 PM
About "Undersun" - parallel but oposite to what you have set - so it will lit faces that you can see not the one in other side.I have set the "Undersun" parallel and oposite to what I have set before, angel -60°.
try those neutral settings as a start:This setting aren't good so I changed glass material to one of lightworks glass material.
Colour: black
Reflectance -> Glass
- specular - 1,0
- transmission - 0,0
- mirror - 0,15
- roughness - 0,0
- refraction - 1,0
Transparency -> Plain
- colour - black
‎2006-09-04 08:23 PM
‎2006-09-04 10:28 PM
‎2006-09-04 11:48 PM
