Visualization
Bug: Sketch rendering AC10 Macintosh
R Muller
If I start to do a sketch rendering, but stop the rendering before it is complete (because, for example, I realize I left the background image turned on when I want a white backgroiund), I am unable to do any additional sketch renderings until I quit from ArchiCAD and re-open the file. Before I quit, all I get for a rendering is a blank white page (as if the previous "stop" command is still being applied).
This happens on an Intel Mac as well as on a G4 Mac.
Workaround is to quit ArchiCAD, then re-open the file.
R Muller
AC 28 USA (20+ years on ArchiCAD)
MBP 64GB Apple M1 Max OS 15 Sequoia
7 REPLIES 7
Dwight
Tested your bug on G5 2X2 and no problem with stopping and re-rendering.
Dwight Atkinson
R Muller
That's interesting. Thanks for testing it.
I can reproduce the problem with a new file containing nothing but a slab, 6 trees, and 2 benches from the standard AC10 library.
What do you suppose is the difference?
R Muller
Dwight
I suppose that the difference is that I am an alien being who can postitively influence the performance of a computer with animal magnetism waves emanating from my forehead, between my anthers.
And you are not.
Dwight Atkinson
R Muller
In that case, I need to knoww how to join you in your alienhood.
R Muller
Thomas Holm
Something is wrong with your installation. Rebuild preferences. If that doesn't work, re-install Archicad.
Djordje
What is the amount of RAM in your computer?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
R Muller
I doubt that the problem is with preferences, since I have dulicated the problem on two different computers (a Mactel laptop and a G4 Mac). Both computers have 2GB of RAM.
I did report it using a bug report, and someone at Graphisoft has "confirmed" it, whatever that means.
I listed it here because, until I realized what was happening and found the workaround, I thought that sketch rendering didn't work at all. I assume there are others who are having the same problem.
R Muller
