Changing materials within a slab
Greetings,
I have modeled slabs for the ceiling/roof components of a mixed use project and I wanted to show a wood material on the underside of the slab only. When I change the underside of the slab to a different material than it was modeled with, I don't see a change. When I tried changing the sides of the slab to a different material, all the surfaces change to that material.
Anyone know how to fix this?
URGENT!! PROJECT DUE TOMORROW!! ANY HELP IS GREATLY APPRECIATED!
Thank you in advance.
1 Reply 1
Eduardo Rolon
If you are using AC17 you need to override the Material by clicking the button. For 16 or earlier you just select it.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
