Changing the colour of brickwork
I have selected the brick wall finish in flemish bond but would like buff/yellow brickwork instead of red/brown. When using the Lightworks rendering engine I can't change the colour. Could anyone assist please?
Thanks
Rob Warren
5 Replies 5
Dwight
What ArchicAd version?
Dwight Atkinson
Sorry that's V11.
Thanks
Dwight
Changing Brick Color:
Preamble:
Most users will appreciate the beauty of the brick patterns in Archicad’s brick materials.
These bricks are made with texture maps and their color cannot be changed.
Until Archicad 11, a texture map with alpha channel was the only good way to get bricks with relief - depth.
Dwight Atkinson
Dwight
What we are going to do is substitute a new shader combination for the alpha channel image. This possible in Archicad 11 since now the brick shader formerly only available as a color shader in previous Archicad versions applies that shader in the Displacement Class - providing depth effects.
1: DUPLICATE the existing Flemish Bond Material. Name the new material
"Flemish Bond SHADER from Dwight to whom i will be eternally grateful and buy his book that will include this lesson as a part of the Archicad 11 supplement"
2: Select the Brick Bonds Shader under Color Class. Select Flemish under parameters. Adjust size and color to suit.
Dwight Atkinson
Dwight
In that same material dialog we switch to the displacement Class:
MATCH the settings for the Color Class Shader with a "Wrapped Brick Bonds" Displacement Class Shader.
Now you have a completely editable brick that also reveals depth.
Yee hah.
Dwight Atkinson
