Visualization
Check Surfaces... What it means in AC20
Does anyone know what this means in AC20... CHECK SURFACES...?!!
I searched in Help Center but no result
No idea how you use it (or if you even need to).
See image for description from Work Environment setup.
David Collins
Once or twice when opening an older file, I've had the Library Manager report a surface bitmap as a missing attribute, but that bitmap was no longer being used in any of the current Surfaces. This usually means Cinerender is still looking for an older bitmap. In the past these ghost attributes were nearly impossible to track down. Check Surfaces searches for "parameters of unused rendering engine(s)" and offers to delete them for you.
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
Erwin Edel
So basically, that button is made of all kinds of awesome
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
