CineRender - Odd thing: Elements beyond glass are invisible
First of all I want to say hello to everyone! I am new here! Quick intro: My name is Rilwan I am a 3D vizualiser/illustrator at a Hungarian architecture firm. Now...
CineRender - Odd thing: Elements beyond glass are invisible...
I don't know how best to describe this, but I am setting up a rendering for work the strangest things are happening to my transparency. and I can't seem to fix this. Perhaps someone here has ran into this situation before and knows a way out.
Basically: Door And Window elements which stand beyond a transparent glass parapet (balcony barrier) seem to disappear/invisible. As in they are simple not visible through refracting through the glass. Their complete shadows are visible. But the element themselves are invisible. Ask for more Screenshot I can add them
5 Replies 5
Here's a another closer image of what I am talking about.
David Maudlin
Rilwan:
See this thread: Window disappearing through glass.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Okay I will set up a signature.
http://archicad-talk.graphisoft.com/viewtopic.php?t=49107
So Yeah! This was actually the first thing I checked to look at Ray Depth and Threshold, and this did not help my situation at all. I tried moving the slider to various values. What else could affect this if it is not Ray Depth? Thanks for helping me.
David Maudlin
Rilwan:
The Ray Threshold and Ray Depth have typically been the culprits. A few things you could try:
1. If the glass is not an ArchiCAD surface, try substituting a default glass to see if it is a Surface issue.
2. Try some of the standard CineRender Scenes (ex: Outdoor Daylight Medium (Physical)) to see if that changes the result.
Thanks for adding the signature.
David
