Just to be clear that it did not work:
• You had a turquoise material that showed correctly using the Internal Engine and in CR
• Then you edited the turquoise to grey and since it shows correctly in the 3D Window I presume you edited the Surface Color in Internal Render.
• If this is the case then IR will be gray but CR will still be turquoise since CR does not update automatically unless you use the Match Settings option.
• That being said if CR remains turquoise even after using Match Settings then it might be that the material has a Texture with that color so changing the Surface Color will not change it until you edit the Texture or remove it.
• Also it might be possible that you need to move the camera a little bit to force a refresh.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08Macbook Pro M1 Max 64GB ram, OS X 10.XX latest
another Moderator
