Cinema 4D Rendering simply stops
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2014-12-16
11:31 PM
2023-05-11
12:01 PM
Noemi Balogh
2014-12-16
11:31 PM
I have plenty of RAM and a fast iMac.....
Anyone else run into this? The only thing that seems to work is quitting ArchiCAD and restarting it...which is a pain in the rear especially if you happen to have a mechanical hard drive vs. an all-solid state memory pack.
Phil Allsopp
ArchiCAD 18
OS X 10.10.1
iMac 27"
Intel 3.4GHz Core i7
AMD Radeon HD 6970M 1024 MB
16 GB 1333 MHz DDR3
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-01-08 12:41 PM
2015-01-08
12:41 PM
Same here!
If I select an object, wall or slab it renders fine but as I try to render the hole scene it goes black after preparing. It never starts to calculate.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-01-08 05:03 PM
2015-01-08
05:03 PM
Is this true for all your files or just a particular one(s)?
Do the problem files generate any errors? (turn error reporting on).
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Mac OSX 10.11.1
AC5-18
Onuma System
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-01-09 02:52 PM
2015-01-09
02:52 PM
Just the one and there are no errors!
I'm in contact with GS on this topic.
http://archicad-talk.graphisoft.com/viewtopic.php?t=47272
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-01-13 01:57 AM
2015-01-13
01:57 AM
I had a similar issue recently with a slab. Though a process of elimination I found a surface that I had manipulated that was causing the issue.
Perhaps check the surfaces? That's all I've got for now mate.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-06-11 09:32 PM
2015-06-11
09:32 PM
Michael wrote:Could you elaborate on this? I'm having the same issue after changing some surfaces. I've tried reverting them back to where they started and I can't seem to get it working again.
Is there a particular aspect of the surfaces I should be focusing on?
Thanks!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-06-30 09:28 PM
2015-06-30
09:28 PM
A ram low speed maybe an issue in regards couple with a dense vegetation landscape can stop the rendering.
