Visualization
Cinerender - Light Settings removing light artifacts
I am confused on how to remove artifacts from the Fluorescent Lamp 19.
I am trying to understand how this one light fixture works so I can get rid of artifacts. If I apply AIR surface to Light fixture and move it down into the space there are not artifacts?
13 REPLIES 13
After some fooling around I made it work by unchecking the shadow box from the Model representation.
This is the result I got
Here is the scene with the lights set up but I need to work on the shadows next.
alemanda
Interesting.
Cinerender produces strange artifacts.
I encountered several troubles with anexterior night scene with IES lamps.
I will give it a try with your method.
Thanks
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
For anyone trying the Fluorescent 19 light, there are some tricks.
1- Do not make it less then 5" otherwise the fluorescent tube dissapears.Then no light source will come from the light.
2- If you need it 5" less then use the glass and apply the Lamp material to emit the light or use a general light.
I will be testing IES lights very soon with the same scene just need to find a good IES file for a 2x4 LED fixture.
alemanda wrote:
Interesting.
Thanks
So here is the IES rendering test.
Definitely slower but shadows are way better.
alemanda
Did you turn off the shadows as well for IES lamps?
AC27 latest hotfix
Win 10 Pro 64bit
The shadows are actually turned back on because the fixture is not generating the light anymore. The IES light object is placed instead to create the light.
I recommend looking the the example files at the bottom of this link
as well as go through each video on the page. Quite worth it in the long run.
http://www.graphisoft.com/archicad/archicad-18/rendering/
alemanda
vgodzb wrote:
..The IES light object is placed instead to create the light.
I don't understand.
What do you mean exactly?
AC27 latest hotfix
Win 10 Pro 64bit
