Visualization
Creating a 3D fly through - camera speed
Iv set up a bunch of cameras around my model and created a fly through around the outside of the building. But I have a problem with the speed.. the camera seems to move to fast along the path.. iv added in more frames, but this seems to just make it smoother.. I cant seem to find any options to slow the camera down on its path? Iv tried the archicad help and still no luck.
Cheers
Gene
Gene
Archicad fly-throughs are very rudimentary. You can set the number of frames per second (in Create Flythrough dialogue, Image compression - Set button), and the number of frames between cameras (in the Camera settings, Path button). These combine to determine speed.
wouldn’t that make it a little hard to get it flowing at an even speed between say 10 cameras all spaced differently apart.. u would need to work out the distance between each one and set them individually?? Seem a little longwinded. woudlnt a "global speed setting" be more user friendly
Exactly.
