Edlihtam
Datasmith Twinmotion Archicad 28
Bonjour Je travail sur Archicad et sur Twinmotion et j'ai téléchargé votre dernier plug-in pour pouvoir travailler sur Twinmotion depuis Archicad sans passer par un modèle 3D. Seulement, Archicad me détecte que l'extension n'est pas à jour et je n'obtiens pas la palette Datasmith dans ARchicad. Pourriez-vous m'aider svp ? Merci
Admin note: Please continue the discussion in English. Thank you.
Translation: Hello I work on Archicad and Twinmotion and I downloaded your latest plug-in to be able to work on Twinmotion from Archicad without using a 3D model. However, Archicad detects that the extension is not up to date and I don't get the Datasmith palette in Archicad. Could you please help me? Thanks
Operating system used: Windows 3.00 GHz
1 Reply 1
You must not have downloaded the current plug-in from the TwinMotion web site.  Go here:
https://www.twinmotion.com/en-US/plugins/archicad
for the US version... to get your local version, you'll have to access via the Epic Games app or your localized TwinMotion site.
Your screenshot is not readable at all... saved with too few pixels.  If you need to post again, please assure that you can read all info in the screenshots that you post 🙂
Here is the Add-On Manager after I copied the new downloaded plug-in into my add-ins folder... and showing the Datasmith palette displayed to export or link...
