Eric Milberger
Decals and Graphitti
I know that I can drape a material on an object - like wallpaper
And hang a picture that has a png file attached
My questions is how to apply a decal or graffiti
I need to place graphics on the walls that are decals or signage panted on the wall
AND
Paint Graffiti art on the wall
Eric Milberger, Architect | Master Planner
1 Solution
Emre Senoglu
so i would first prepare the file in png format, with the correct transparency. then create a material in archicad, turn the transparency layer on. then assign that material to a wall element to only one side of the wall. the other materials of the wall should be an empty material. alternatively, you could use a picture frame for the same method, but i think it would be easier with the wall, due to the limited material settings in the frame gdl object.
you wont get a perfect decal, but it will do the trick fast. here's a video showing how to do all this:
https://www.loom.com/share/3395000938cc47c1b51ce438a2f75048
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
Go to post
4 Replies 4
Emre Senoglu
Carstenem
I recommend watching this tutorial to add your graffiti. You can use the diffuse channel as long as your graffiti image as an alpha channel.
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
Eric Milberger
Emre - thank-you this is perfect. The picture and drape will not work but his does perfectly for both painted work and graphics
Emre Senoglu
hey eric, great to hear.
