Visualization
Disable Cinerender
sarahric
Is there a way to switch off Cinerender?
I never use it.
When I look at task manager processes it appears seperate to archicad but using a lot of memory I could use else where.
ArchiCAD 18/Windows 7/16GB Memory/i5 3.2GHz Processor/NVIDIA GeForce GT 610
eldhead
I noticed that to. I just stop the process.
Archicad 7 - 24, HP ZBook 15 Mobile Workstation, Win 10
I wouldn't disable the process, just add more RAM 4Gb is barely enough to run Windows 7 let alone a BIM program.
16Gb seems to be the best value (less than $150) with resultant boost in system performance and stability.
Scott
