rob2218
Does AC18 still have the "lighworks" rendering engine?
I'm having a hard time "controlling material and texture" darknesses and lightness' and tones with the Cinerender engine.
Does AC18 still contain the Lightworks Rendering engine?
If, were is it and how do I get to it??
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
5 Replies 5
rob2218
if not, then can someone point me to a GOOD tutorial on how to use the new Cinerender engine cause geez.....I can't seem to "tweak" colors and tones whenever my client wants "changes" to rendering look.
any help would greatly be appreciated.
i>u
Edgewater, FL!
SOFTWARE VERSION:
LW is gone:
http://helpcenter.graphisoft.com/guides/archicad-19-int-reference-guide/migration-guide-for-archicad...
rob2218
Karl,
ok....if LW is gone, then is there any...any tutorial at all that can show me how to make "blue" come out in textures with the new Cinerender engine?
Geez....all these settings are bare to manipulate and I'm not sure I'm manipulating them properly.
My client wants "greyer/blue" to come out in wood siding pattern....not sure WTH I have to do make that color "blue" come out in the texture.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Various ways, where the oldest method of editing a texture in Photoshop and tinting it/etc as desired of course always works.
Attached shows how you can dynamically add color to an existing texture using the Color channel and setting the mix mode to Multiply. Pick your color, mix strength and brightness.
Note that luminance, specular and more can affect color, as can illumination including ambient light. Same as before with LW.
I found the Archicad videos on the Graphisoft youtube channel really useful. Plus the texture provided as part of the select subscription are very good and easily modified.
