Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Visualization
Render your model with built-in or 3rd-party solutions
EGG SHELL
Could someone please enlighten me at to the cause of the wavey line at the top my walls? Image attached:
3 REPLIES 3
Dwight
Other than demonic possession i would look at shadow resolution being too low.
What lights are you using and what are their settings?
Dwight Atkinson
I clipped the settings - attached:
Dwight
Besides turning off the idiotic Camera light, there seems to be no problem here.
Make "Smooth Surface" active.
But you aren't showing the light settings.
They would be: any lamps in the scene and the actual SUN settings as in the LightWorks Environment.
Dwight Atkinson
