Karl Wir_n
Edit camera path spline 3D
Hi, i'm making a fly-through. In the plan view there is a possibility to adjust the spline in order to control the smooth movement between cameras. Is there a way to control the movement in other views then the plan view? That is, to edit the spline not only in the xy-plane.
Thank's
2 Replies 2
I don't see a reply to this, but this really is a problem. I keep ending up with a "fish tall" movement that I can fix in xy but not in z. If there's a way to do this, please reply!
You can't adjust a camera path in 3D - only in plan.
Each camera along that path has settings for camera height, target height, azimuth and roll angle, that will affect the height and angle that you are viewing the model from.
