Visualization
Electric image
I am trying to export to Electric Image from archicad. all of the rounded surfaces show their polygons. I exported to 3ds and then imported to EI and everything was well rounded but hte scales was off and the objects had names like 1,2,3,4,.... Which is not at all helpfull.
Any ideas???
Jose
Petros Ioannou
Try another type of 3d file(3dS,OBJ).I am not familiar with file types EI imports.
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
I save from ArchiCAD as fact. but don't forget to run the model thru EI Transporter. Run it once normally, and run is a secont time and have it recalculate the surface normals then save as a seperate model. Try these two in EI and see how they render. It may just be a surface normal problem.
If that doesn't work, I would try OBJ export from ArchiCAD.
