Visualization
Elevations and Plans Renders
how to do elevations and plans photorealistic archicad to generate photo-realistic or artistic images to sell design ideas in archicad?
Ingolf
In the following way you can render a picture of your elevations: Choose the 3D Window with Axonometric view (Ctrl+F3). Bring forward the Dialogue Box of the Axonometric View by punching Ctrl+Shift+F3. Use the Azimuth function and choose angles that are perpendicular to your elevations so that the camera looks at the elevation straight ahead. Typical values here (if your house is oriented North-South) is 0, 90, 180, 270.
Click OK to orient your house in the direction you choose.
Now click F10 to render.
(Free stuff from my books)
Ingolf Sundfør, Bricklayer, Author of several Real Life Problem Solving Books for Archicaddicts in Norway.
PC/i7/W11/ArchiCAD 6.5-27
Steve Jepson
You can view your objects in 3d then use the 3D Cutting Planes Dialog Box if it helps to get the view you want to render.
View > Elements in 3D View > 3D Cutting Planes
Ctrl+Shift+Y
Use the "Look to Perpendicular" button in 3D navigation palette / menu and pick a wall surface to be perpendicular to.
