Error with Internal Render Engine
I´m drawing a 6th floor building with "Internal Render Engine" and the trouble is: "Waring! Not enough memory (or disk space) to create all shadow bodies".
I´m working with a PC AMD Ahlon 64 Processor 3000+2.08GHz, 1,00GB RAM, MIcrosoft Window XP Professional 2002 Service Pack 2. Virtual memory 3000MB
Thanks,
Gabriel
1 Reply 1
Dwight
Which mistake?
Actually using the Internal engine, or something else?
The disk is full because during the 3D visuaizing process, a temporary file that contains all of the GDL scripts "constructed" as individual elements and the light and surface calculations are stored.
There's not enough room on the disk to contain this file. It could be gigulonz in size.....
does it not happen with LightWorks?
Dwight Atkinson
