‎2004-05-24
04:50 PM
‎2023-05-11
04:01 PM
Noemi Balogh
‎2004-05-26 08:44 PM
mathome wrote:Did you try the Shockwave exporter? Not free ...
A client wants to walk around in a building we are working on and I tried exporting VRML to use in Octagon VRML player
‎2004-05-27 01:14 AM
‎2004-05-27 08:47 AM
Djordje wrote:I tried it and it is promising, though doesn't meet my wishes at the moment. I will stick to the v8 demo version of ArchiCAD which is an excellent browser if you're prepared to spend just a little time with the interface.mathome wrote:Did you try the Shockwave exporter? Not free ...
http://www.dunako.com/archishock3d.html
‎2004-05-27 10:16 AM
mathome wrote:If you have VIZ, then do try that road. It doesn't have to be too spectacular to be very usefull.
We have 3DS Viz at the office and I will try to export vrml through 3DS even if I think 3DS is a great time consumer....
:)Mats
‎2004-05-27 12:46 PM
stefan wrote:Thanks Stefan! I will try 3DSViz with your tips. (wish I had more time...)mathome wrote:If you have VIZ, then do try that road. It doesn't have to be too spectacular to be very usefull.
:)Mats
Just make sure that it end up on the right scale, meaning one "unit" in VIZ will be translated into one "meter" in the VRML model.
You can set your VIZ system unit to one meter and then make sure the export from ArchiCAD uses 1000 mm as unit settings. When importing, let VIZ "convert units". That way, both the units & measurements in VIZ will be correct. This also makes sure that radiosity rendering uses the correct units. When that is fine, the model is on scale in VIZ and through the VRML export.
‎2004-05-27 03:19 PM
mathome wrote:Yes, an excellent point Mats. Why in the world won't Graphisoft just package the 3-d window browsing capability of ver8 as a stand alone, non-editing viewer. Include a beginner GUI, perhaps recorded paths, cameras, etc so that we can direct the viewer also.mathome wrote:
:)Mats
‎2004-06-01 11:56 PM
mathome wrote:Have you tried the Cortona VRML viewer? It's available as a browser plugin from
A client wants to walk around in a building we are working on and I tried exporting VRML to use in Octagon VRML player (http://www.octaga.com/download_freeplayer.html).
‎2004-06-07 09:24 AM
