GDL Enthusiast
Export with Alpha Channel
I am trying to export from the floor plan with an Alpha Channel. Every option I have tried of the export results in an image without an Alpha Channel when re-opened. I have tried all image types, Tiff, Jpg, Png, exported with Alpha channel or high quality with Alpha Channel. I have tried exporting the image with a transparent fill in place, and also with a fill set to background. Still no Alpha channel present. Is this a known Archicad bug or am I doing something wrong?
Many thanks in advance!
Rajesh Patil
If you can elaborate the use of the alpha channel, say looking for transparency or bump, I may be able to help you. Also any end product image you can provide?
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
GDL Enthusiast
Hi Rajesh,
Thank you for responding. Attached is a screenshot of what is on the floor plan before export. Attached is a screenshot of typical export settings with Alpha Transparency. Lastly attached is the exported image (zipped as this site wont allow uploads of a TIFF file). I cannot seem to find any other options for export and would welcome help.
Ideally I would like to export anything I create on the floor plan e.g. a site plan or a small detail drawing, and with that export it with a transparency. It is great for post processing work in image editors. Thank you again for responding and all the best!
