Erwin Edel
Cinerender alpha channel in front of transparant surface
Does anyone know if there is a fix for this issue?
I've gone over a lot of settings, but can't seem to find one that fixes it.
If I have images with an alpha channel, they render just fine in front of surfaces without transparancy, but in front of glass they get white edges/borders.
It's not the end of the world, but I would like to get rid of it, if possible.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
5 Replies 5
DGSketcher
Legend
@Erwin Edel the white on the glass looks to be more of an attempt at reflection rather than white borders. Perhaps a new glass with a lower reflectance value might improve the image?
Erwin Edel
I've tried all the different 'normal' glass surfaces from the catalogue and different type of alpha channel transparancy images. They all give a similar result.
www.leloup.nl
Erwin Edel
Small update. It does seem to be issue where the surface behind the glass is rendered without shadows, reflection etc
A few quick tests I did:
no walls behind the glass, no problem
a white wall with ceiling for shadow, you get the white spots again
I made the wall blue, now the spots are blue
www.leloup.nl
DGSketcher
Legend
Random suggestion of the day: I assume you are just using sunlight, what happens if you add a general light within the room still with the sunlight?
Erwin Edel
With some generic interior light and sun:
Without sun and only that generic light:
So sunlight does seem part of the problem.
www.leloup.nl
