Visualization
FLY TRHOUGH - batch publishing
alemanda
Is there any way to publish Fly-Through in an automatic way, like publishing?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
Erwin Edel
Unless you intend to view it in BIMx, I do not think so.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Pato99
The answer is no.
maybe?
If you set the flyaround settings first (to say 24fps) then you make a camera path with 100 frames per camera, you can put that canera path in the publisher.
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
