First time using Rendering: Rendering too dark
Hi i am inputted a photo onto my structure wall on my work. It if comeing through very dark on 3D view i have been told to render the photo which should help the situation. I am having problems in doing this. I go through the photo rendering settings and i still cant get this to come through light or any change at all. Can someone advise what the best settings to use for rending.
Many Thanks
1 Reply 1
Guru
Not quite sure what you have done...
You have applied a photo as a texture to a wall and it is coming out dark? Is the structure dark when you use one of the default materials?
Ling.
