Flythrough Speeds
How can I make a flythorugh that isn't lightening fast? I have messed with every control I know how to mess with and it goes from fast to ultra fast. How can I set the speed down to a speed that would be like someone walking through the room??
Thanks!!!
2 Replies 2
You either need to put your cameras closer together (ie. more on the path) or increase the number of frames between cameras.
Increase the number of inbetween frames in the path settings found in the Camera dialog box. Remember that a fluid animation runs at about 24 or 25 frames a second. Calculate how many seconds you want to take between each camera, and times by 24/25. You can add additional cameras to help slow the pacing further. Remember to set the playback framerate to 24/25 fps also. You may find you can get away with less fps, but you will have to experiment to find the minimum.
