Visualization
Getting my 3d model to line up with a photo ?
I have a photo of an exisiting site.
I also have an archicad model.
I need to orientate my archicad model to the exact same perspective as in the photo, then render it and drop it into photo shop.
whats the best strategy for this ?
thanks guys.
Ian
11 REPLIES 11
You can use:Document/Creative imaging/Align view
For more info please check the Help
Best regards, Ede
Erwin Edel
So far I've found that 'eyeballing' it and then tweaking the render in photoshop has given the fastest results. Tip: you can set the photo as background image in your 3d window in 3d window settings.
I suppose my method of doing this works well because most of the montages I did were on sites with a fair few buildings around to get a good sense of scale.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Dwight
And in the case of an irregular structure, place a translucent box around it to simplify vanishing point location.
Align View is unreliable for exterior views unless the photo is accurate and possesses measurable reference lines.
Attached is a page from my "Artlantis Attitude" book giving some further hints.
Dwight Atkinson
vistasp
These two articles may help you:
http://archicadwiki.com/AlignView
http://blog.graphisoftus.com/graphisoft/align-view
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
can some one please show me where this is in the menu.
i cant see it in my archicad german version.
thanks.
ian
Document/Creative Imaging/Align View
thanks.
ian
This...
yup thanks.
i was able to do it but i found the results really not good.
the general perspective was ok but the correct angle and camera height was tottaly wrong and just took me ages to tweak until it was close.
it only worked becasue i had two monitors, one with the photo and the other with archicad and the camera position.
I dont think this tool is very good.
Thanks.
ian
Sightline
Perhaps this happens because pictures are taken with real cameras with focal length, aperture width and lens distortion. You would need software that emulates physical cameras such as Cinema 4D in order to match the view.
There is a plugin for C4D called Photomatch and even with that, it's not that easy to align views.
Diego Torres
Architect-CG Artist
Architectural Concepts and Visualizations
ArchiCAD 4.55 - 24
http://www.sightline3d.com
Dwight
Photo Match works fine in theory. Just make a rendering of a scene and use it as a background to insert another element. Once free of real world anomalies, the feature is flawless.
Dwight Atkinson
