Visualization
Glass: looking through
How can I make the glass transparecy so I can see objects through the other side? Can I change the size of the tiles?
Also this is my first rendering if anyone has any tip or suggest about it I appreciette.
Thanks
4 REPLIES 4
Michal Forejt
I would suggest you to post this to:
Presentation-Rendering and Multimedia
Surely you will get proper answer there. Just add a little bit more informations. Especially what version af ArchiCAD do you have, what rendering engine did you use (Internal engine, LightWorks etc.).
Those informations are necessary. Without them they can't help you much.
Best,
Michal
ArchiCAD 27
WIN 11
AMD Ryzen 5 7600X 6-core
64 GB RAM
NVIDIA GeForce RTX 3060
Dwight
It seems that if this is really glass, and the user hasn't inadvertently made the glass opaque, he is probably using a render method of normal
Normal = useless.
By selecting successively better rendering methods, increasing layers of glass will become transparent.
Dwight Atkinson
Thanks a lot guys.
Hi Bitoque, sincerely, why don't you get some training in Portugal since there are a lot of distributors with training center....it would be more rentable for you, as all your doubts would be clear.
for using archicad is better follow some learning method instead of trying to solve everything alone (and sometimes in the not best method)
best regards,
