Visualization
Good texture resource - Arrowway shaders?
Hi guys,
i want to get the most out of the lightworks rendering engine in ac12 so i would like to find the best resource for materials.
the arroway textures seem to be good.
is any one using these in ac12 or can you not do high res renders with lightworks.
i would apreciate your advice / tips on this
thanks,
Mark
1 REPLY 1
Dwight
It is touching that you have such dedication to an outmoded rendering tool.
The fundamental drawback in LightWorks is adjusting lighting, because the basic engine as implemented in Archicad can do almost any surface well.
Before investing, review the archive surfaces [load settings from archive] that are supplied with Archicad but not made into materials yet.
Your issue in high resolution rendering is not the texture images, but slow production of larger images. SLOW. KRIKEY!
Arroway, Dosch, or whatever, are investments that will do you well once you move on to a real rendering application, even if you reduce them to 1000 pixel files for use in LightWorks.
Dwight Atkinson
