Visualization
Grass texture - No repetition in pattern
Is it possible to create a nice looking grass texture without any repetition in the pattern.
I have downloaded the grass textures from cgtextures.com. (the tiled ones)
But still the grass texture looks bad, when watching from distance.
I should use this texture for my bimx models.
Not for closeup renders and so.
Does anybody have one, which looks awesome in bimx models and is not heavy for the memory consumption.
regards Martin
It's difficult for the BIMx models since they use a simple texture mapping. For grass it would have to be very large or very uniform/homogenous to minimize the tiling.
There are tricks in more advanced renderers (including the embedded LightWorks engine) using alpha masks but I don't think this works in OpenGL.
Hi Matthew
I thought so.
I just haft to find the most suitable grass texture with less repetition, without having to put a very large grass texture in the model.
regards Martin
Sightline
The Seamless Texture Generator might help!
http://www.seamlesstexturegenerator.com/testindex.html
Diego Torres
Diego Torres
Architect-CG Artist
Architectural Concepts and Visualizations
ArchiCAD 4.55 - 24
http://www.sightline3d.com
