alex_kemp
Custom Surface Catalog: issues saving out surfaces to .gsm file
I am in the process of creating a Custom Surface Catalog for our office in AC25. I have been ceating custom surfaces using this method: https://gdl.Graphisoft.com/tips-and-tricks/how-to-create-a-custom-surface-catalog
1. Normally when I 'Export to GSM' it creates a SurfaceName.gsm, FillName.gsm and a folder [TImg] textures with texture image inside. A few of my surfaces are also exporting another Pattern.gsm file (see screenshot) when i save them out and I am unsure why, does anyone know what this file is or what is causing it to generate??
2. I had primarily been using jpeg's and png's as the Surface Texture Image. I have since tried to use a .bmp as the Surface Texture Image as they were available on Colorbond website.. I am now having problems with my library becoming corrupted and windows file explorer crashing until I remove the folders containing .bmp files. Has anyone encountered this problem? Wondering if it has something to do with the file type...
Thanks for your help!!
0 Replies 0
