‎2006-07-11
11:27 AM
‎2023-05-11
02:40 PM
Noemi Balogh
‎2006-07-11 03:20 PM
‎2006-07-12 01:58 PM
Dwight wrote:What if my light source is General Light, which doesn't have any shadow quality settings?
When you get grainy shadows, it is because of lack of resolution in the shadows - so look at your light sources.
If there are any parameters referring to shadow quality or resolution, put these values up over 3.
‎2006-07-12 09:09 PM
‎2006-07-12 09:13 PM
‎2006-07-13 02:21 PM
tigr wrote:Thanks - I increased my sharpness from 1 to 3 and it has seemed to solve the problem.
- decrease the detail factor
- increase the sharpness factor
in your roughness settings.
Dwight wrote:Tried this as well, but it made the walls a bit glarey. But, you were right about shadow resolution, I added a window light with shadow resolution at 3, and the rough bits went away...
Just to test, completely eliminate roughness from the surface - I was wrong about shadow resolution...
