Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Visualization
How can I get reflectivity on glass surfaces.
I'm having some trouble getting my 3d glass surfaces to reflect objects
around them. I'm sure it's not too difficult but it's really starting to rash me that I can't get it. ?Anyone? Thanks
3 REPLIES 3
The ArchiCAD rendering engine doesn't support ray-tracing so actual reflections aren't possible (unless you export to Cinema 4D, Artlantis, etc.). You can do some old tricks though. Like texture mapping a semi-transparent image onto glass or inverting a copy of the building to appear reflected in water (a rippled, sparkly, transparent texture can help with this illusion).
Djordje
Go to www.abvent.com and download AV Works. Rework your glass material(s) to wanted level of reflection. Done. Within ArchiCAD.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks a lot. I'm trying to get my boss to get artlantis but that abvent.com sounds good. Really appreciate it. Thank you.
