How do I save plan view as image w/decent res.
I'm asked to do a large color site plan. When I save a plan as an image file it only gives a 72dpi image. I need a much higher resolution so that I can open it up in Pirenesi and create a nice plan quickly. How do I do this?
Thanks
mark g
architect
ac9 macOSx
I've done many renderings with Piranesi just not a site plan rendering.
Eduardo Rolon
There are different ways to do this but since you are in OS X the easiest is "print" and use the "save to pdf" option on the Print Dialog. Open the Pdf in PhotoShop and there you can specify the resolution for the image...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
