Visualization
How do I use Surface Painter without using mouse?
I am kind of annoyed with no quick key. I am tired of using mouse to click on one surface color for everything. I had to click one a time back and forth a time. Is there a way that i can use quick key and repeat over and over? Anyone can share with me? I am using AC 19. Big thanks!
4 REPLIES 4
sinceV6
Hi.
Have you tried to change the "Start paint mode" to "infinite"? That way you just click on the surface you want and click as many times you need to paint surfaces on your model.
Unless I do not understand what you need.
Best regards.
Yes, How do I get it infinite? That is what I am looking because I usually use the same material all over the place.
sinceV6
On the top part of the Surface Painter palette, long click on the paintbrush.
Thank you!!! I did not know there was hidden button the whole time. Ha.
It was a huge helpful! Big thanks!
