on
2026-04-21
08:23 AM
- edited on
2026-04-21
08:24 AM
by
Aruzhan Ilaikova
This article introduces a streamlined technique to showcase a project’s real-world context in Archicad, using a custom skydome object and a 360° site photo. It is intended for Archicad users who want a realistic site background in 3D and BIMx without detailed context modeling.
Users need a light‑weight way to visualize real‑world surroundings in 3D/BIMx without complex modeling.
This method uses a GDL-based skydome object in Archicad, where the outside of the dome is transparent and the inside displays a 360° panoramic image of the site. This approach quickly creates an immersive environment around your model, ideal for both in-Archicad visualization and BIMx presentations.
Note that this trick requires Archicad 27 or later and Physically Based Rendering in 3D must be enabled in your Work Environment settings, like this:
A skydome in Archicad where the external surface is transparent, and the internal surface is a 360o picture of the actual surroundings of the site.
For more information on how this GDL skydome object is set up, watch this video.
Additional Archicad objects and video tutorials created by this Community member are available here:
| YouTube | BIMcomponents |
These techniques were originally shared by Community member @Hmooslechner. If you’d like to explore the original discussion, click here to read the full thread!
This article is part of the ‘Tip of the Month’ series on Graphisoft Insights, highlighting valuable community-driven solutions for modeling challenges. Try these methods in your next project and experience the difference in model quality and efficiency.
