Create a new MATERIAL, or modify an existing one. This is done in Options>Element Attributes>Materials
Choose your image as the covering texture, in the TEXTURE panel. Note that the image file must reside in a loaded library (see File>Library and objects>Library manager)
Once created the desired Material, assign it to the element surfaces (MATERIAL panel for the WALL setting window).
You can see the material in the 3D Window, when in OpenGL mode (not with Internal Engine), or in the Fotorender.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
