alemanda
IES Lights - bug?
I'm struggling with IES lights. I think there's a bug in the IES light library part or in the cinerender engine.
I set my scene with different ies lights but what I note is that different photometries are rendered with the same power. Light distribution is correct but 70W or 2W - for example - are rendered with the same light intesity intensity.
Did anybody encounter this problem?
Is it a bug? Is there some magic setting for Archicad to process the image correctly?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
2 Replies 2
alemanda
I made a comparison with some spot light object.
What I noted is that the light intesity is correctly rendered with spot light while ies light are rendered in the same way despite different light intesity.
I think there's something wrong in the IES light object.
AC27 latest hotfix
Win 11 Pro 64bit
alemanda
Ies lights are set with "use photometry data" and light intesity to 100%.
AC27 latest hotfix
Win 11 Pro 64bit
