Visualization
IES Lights - bug?
alemanda
I'm struggling with IES lights. I think there's a bug in the IES light library part or in the cinerender engine.
I set my scene with different ies lights but what I note is that different photometries are rendered with the same power. Light distribution is correct but 70W or 2W - for example - are rendered with the same light intesity intensity.
Did anybody encounter this problem?
Is it a bug? Is there some magic setting for Archicad to process the image correctly?
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
alemanda
I made a comparison with some spot light object.
What I noted is that the light intesity is correctly rendered with spot light while ies light are rendered in the same way despite different light intesity.
I think there's something wrong in the IES light object.
undefined
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
alemanda
Ies lights are set with "use photometry data" and light intesity to 100%.
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
